Re-setting remote central locking????
JULEE
Post by JULEE »
Hi all fellow Polo's
Since I disconnected my battery from my car to replace a thermostat (but then realised battery could stay were it was -derr), my remote central locking has not worked. I have two sets of keyfobs and tried both. Is there some sequence to resetting the central locking after the batery is removed. The keyfob is for the alarm and the remote locking. Now only the alarm works and the locks have to be opened/closed manually with the key. I have had the pump tested to see if it runs and it is working fine. I've checked the appropiate fuse in the fuse cluster also.
Help. :D
