mmh
Posts: 268 Joined: Wed Jun 22, 2005 6:42 pm
Post
by mmh » Tue May 23, 2006 5:42 pm
Could someone tell me what the tyre pressures are for these wheels:
Also is there a way of finding the pressure from the info on the tyre wall?
Cheers,
Mo
polo boi
Posts: 724 Joined: Tue Feb 21, 2006 7:48 am
Post
by polo boi » Tue May 23, 2006 9:17 pm
man, all car tyre pressures are around 30 - 32psi
polo boi
Post
by polo boi » Wed May 24, 2006 8:26 am
and i think the tyre wall may say on it but im not sure, i dnt think they do anymore, but its 30-32psi.
luke
Posts: 64 Joined: Mon Oct 10, 2005 11:56 pm
Post
by luke » Wed May 24, 2006 1:42 pm
cant exactly see from the picture but if they are theres tyre info on the petrol cap flap. should be on the tyre wall somewhere though it usually is.
Luke
polo boi
Post
by polo boi » Wed May 24, 2006 4:02 pm
i used 2 work ina garage an fitted tyres everyday an all car pressure were around 30 - 32psi, mabye the odd 28 but u cant go wrong puttin 32 in, its right believe me, i put 40psi in mine as i dnt have power steerin an this improves it, but it can b risky but it has 2 b done
Tris
Posts: 631 Joined: Fri Nov 25, 2005 12:42 pm
Post
by Tris » Wed May 24, 2006 10:08 pm
I believe it's 28 psi but I usually put in about 30.
Some bigger cars are 36!
DON'T put in what it says on the sidewall, that's the maximum pressure
polo boi
Post
by polo boi » Thu May 25, 2006 11:47 am
u cant go wrong with 30psi
Randall
Posts: 909 Joined: Sun Sep 26, 2004 8:47 pm
Post
by Randall » Thu May 25, 2006 11:54 am
have you checked inside your petrol cap? this is where i found the tyre pressure info for mine
spot_on_jon
Posts: 164 Joined: Wed Oct 05, 2005 11:53 am
Post
by spot_on_jon » Thu May 25, 2006 12:07 pm
polo boi wrote: and i think the tyre wall may say on it but im not sure, i dnt think they do anymore, but its 30-32psi.
if its not on the tyre wall it should be, a sticker on the passanger door by the actual lock bit..... or it will be in ur service/manual book.....
mmh
Post
by mmh » Thu May 25, 2006 1:26 pm
Cheers for the info.
Unfortunately there's no sticker in the fuel cap, there is a sticker near the passenger lock but all the writings rubbed off.
I'll put in 30psi which sounds about right.
Cheers,
Mo
polo boi
Post
by polo boi » Thu May 25, 2006 10:44 pm
No Problemo
