Bastard Audi TT pedals!!! Help!!
Si_GTi
Moderator
Post by Si_GTi »
They will fit! It can be a b1tch of a job though to get them on right haha! For the clutch and brake pedals, get the rubber fitted around the top of the pedal and then use a small screwdriver to pull the edge of the rubber out and around the pedal help get them on properly. I had the most trouble with my clutch pedal, but patience and a few bruises got me there :lol:
ModifiedMadness
Sponsor
Post by ModifiedMadness »
I found the Clutch was the easiest one, as Si says use a small flatheaded screwdriver to help you get them on, either get the top on first or the bottom.
15 minute job, max - So come on Alun, stop messing about and get them on :lol:
omicron
Post by omicron »
Don't know if it's the remotest bit of help, as I don't know what TT pedals are like. But when I fit pedal rubbers, I warm them up with a hairdrier first.
olop_chris
Sponsor
Post by olop_chris »
I found them to be really easy :?
i fitted them from the bottom up, pulling them over, i used a flat screwdriver like everyone has said to help them get over and went on fine.
concentrate on them and they'll be on in no time lol :)
ModifiedMadness
Sponsor
You can get carpets from VW yeah, not sure how much they are though.
What did you use to fix the gas pedal on?
ModifiedMadness
Sponsor
You must have stuck the gas pedal down somehow though because it doesn't fit otherwise, I had to use Doublesided Duck Tape
olop_chris
Sponsor
ModifiedMadness wrote:You must have stuck the gas pedal down somehow though because it doesn't fit otherwise, I had to use Doublesided Duck Tape
Again, mine also fit with no tape, and its still on fine to this day!
was i just lucky? lol
GaryUK
Post by GaryUK »
I know your pain mate, took me ages fit them to my 9n and lots of swearing lol, the pic doesn't look right, push it down at the bottom more.
I read a handy tip somewhere to put them in warm water to soften them up abit and it might make it easier.
8)
ModifiedMadness
Sponsor
Yeah, looks fine to me.
I know that a few of us have had to fix them down, whereas some have been ok.
Don't know why that is.
Si_GTi
Moderator
Post by Si_GTi »
My gas pedal isn't taped on but is on OK, you can take it off with very little trouble but in normal driving its perfect. I really *should* tape it down though!! :)
