[phpBB Debug] PHP Warning: in file [ROOT]/ext/cleantalk/antispam/model/CleantalkSFW.php on line 184: Undefined array key 1 Induction Kit - UK-POLOS.NET - THE VW Polo Forum
i dnt think there is man, all i know is my filter is this
and an induction kit just has a longer pipe, but there no real difference, just that the induction wud send more cool air through ur pipe, but u still get the same tone, my mate gave me this K&N as it didnt fit his car
Hey all, quick question..... I have a 1.0 litre with a drilled airbox. To be honest I think it sounds great and loads of my friends like its tone but was wondering is there any good induction kits or even a universal one worth trying for a more ferocious or raspier sound?! any ideas?!
see my filter, thats universal coz it was off a saxo an it fitted mine, believe me man, its a great tone an it does increase the spped a bit as mine is also 1.0
Cheers mate, Is it universal or is it meant for a saxo and just happens to fit?! Does it need anadaptor or anything? wonder where I would track one down and how much approx?!
its actually universal, u can get these an they are universal K&N's as sum engines have the same diameter throttle body, an noe i didnt need any adapter, its on as u see it, a simple filter with a metal cable tie which u just tighten on2 the neck of the throttle body, easy peasy oh an theres a pipe for the oil pipe 2 connect 2.
Good stuff.... Thanks lad. You dont happen to have a part number or anything do you or has it a name?! See here in Ireland Is a b***h to try trqak stuff down....
im up north man in northern ireland, there no number, all i know is its universal or u cud just get a k&N filter off sum car sites which are for polo's, just so u dnt buy the wrong 1
Its Powered through a 150watt power inverter I got from Halfords. The power inverter gets wired directly to the battery and the playstation simply plugged into the side of the inverter with the normal domestic 3 pin plug. The whole lot is hidden up behind the dashboard. Great job really and if need be I can plug out my ps2 and plug in my hair dryer ha only messin!
