theres 2 screws at the top an 1 underneath the headlight, in between the bumper an the light, u unscrew it from the front of the car, just push the bump dwn a bit or the headlight up an u will see it, then once u lift it it will pop out from sum plugs, disconnect the wiring plug then chazam, its out, an this is from the haynes manual
