Strange phenomenon
polokaj
Strange phenomenon
Post by polokaj »
Well i've been having idling problems with my 6n 1.4 16V. so i bought some carb cleaner and sprayed it into the throttle body all seems fine still needs a proper test drive. But while reving the engine i noticed if i let the car idle and just tap the throttle pedal the car would rev to 2000 rpm and stay there without my foot on the pedal, then if you tap it again it settles back to normal anyone explain this or is it my worst fear that my throttle bodys gone and i need to replace it.
Az
olop_chris
Sponsor
Post by olop_chris »
Im no expert, but maybe your clutch cable is catching somewhere?
RR Livi
Post by RR Livi »
i had the problem a while back - i took the airbox off and shifted all the dirt out and gave the cable a clean up, sprayed some WD-40 (seems i use this alot lol :lol:) and pressed the accelerator cable a few times with the engine off - hope that helps you :D
polokaj
Post by polokaj »
RR Livi wrote:i had the problem a while back - i took the airbox off and shifted all the dirt out and gave the cable a clean up, sprayed some WD-40 (seems i use this alot lol :lol:) and pressed the accelerator cable a few times with the engine off - hope that helps you :D
cool will give it a go.
any more ideas?
loud
Location: 25 miles south of Aberdeen Drives: 9N3 Polo GTi
Post by loud »
you might have left some dirt somewhere on your throttle body that is making it stick open
