Guys about 3 years ago i had my car fitted original Fog lambs...mine is 6n'98 1.6.... But the service did not use relay.... this has been in my head for 3 years...
97 and 98 ' are different...97 has place in its ????? box. Guys i am sorry i cant remember the name of box...there are some small plastic things with saying 15 amp , 25 amp and these numbers change by the color...i think i you understand me...As i said before 97 models has place for this relay but mine dont...So what should i do..??
thanks alot in advance....
Should I have used Relay ???
The FASTEST
- Josh_PoloGTi
- Drives: BMW E85 Z4 3.0i
The FASTEST
Tahrey1043
The FASTEST
Late reply i know but the decisive answer to the question is:
What is the switch rated at in amps? 2, 5 ,10 ?????
What bulbs are in the fogs?
E.g
2x 55watt bulbs running on 12V draws 9.16 amps.
55 watts x 2 bulbs = 110 watts / 12volts = 9.16 amps.
If the switch is rated less than this then it will work but fail prematurley like previously suggested.
Fuse should be roughly double the constant currant draw so in this case no less than 15 amp and no more than 20.
E.g
