offset
jamesthomas404
offset
Post by jamesthomas404 »
what is the ideal offset for a mk4 polo, lowered 40mm, thanks, james
polopowah
Location: Hertfordshire Drives: Ford Puma 1.7 Enjoys: Mowing grass
Post by polopowah »
et 33-35 you should be looking at
-Ben-
henry01
Post by henry01 »
hats alright if only 40 low. but if you go much lower they may scrub depending on the rim width.
jamesthomas404
k thanks a lot lads
Alex_6n2
Post by Alex_6n2 »
henry01 wrote:hats alright if only 40 low. but if you go much lower they may scrub depending on the rim width.
I doubt it somehow. ET35 would put them inside the arches so they wont scrub the outside unless they are super wide.
