coilovers?
polo power
coilovers?
Post by polo power »
hi there im looking at buying some coilovers but im not to sure what maufacturer to go with, could anybody suggest any good coilovers priced about 300-400 pound.
cheers tim
Ollie_R
Sponsor
Post by Ollie_R »
Give Mertsham_Phil a PM. He sells a coilover kit for the 6n2 for £280 by Evo. He also sells other coilover kits, such as KW, H&R and FK. He's a good bloke, and sorted me out with a suspension kit for my car. If you're signed into CP, it'll be easier to do it that way, since he's probably on there more than here, I guess.
http://www.clubpolo.co.uk/forum/index.p ... opic=35524
If you don't fancy those, there's more expensive options, but you'd have to shell out more money.
polo power
ok then cheers for that
badboypolo
Post by badboypolo »
with coilover would i get rubbing with 16inch wheels?
badboypolo
badboypolo
Si_GTi
Moderator
Post by Si_GTi »
No, no, and no to the third post as well :lol:
Basically coilovers are height adjustable so if you find there are clearance isues, just raise them up a bit until they don't rub or catch :)
badboypolo
oops !
so can you adjust them yourself with no prob?
Si_GTi
Moderator
Post by Si_GTi »
AFAIK simply jack the car, take the wheel off, and adjust the thread. I don;t own coilovers myself but I've done a lot of reading :lol:
DanDiesel
Sponsor
Post by DanDiesel »
sometimes u don't even need to take the wheel off!! (i will have to tho)
with mine its a case of loosening a sorta clamp and then winding the top half of the clamp up or down and then when ur ready, just resecure the botoom bit of the clamp!!!
i didn't think it was that easy uintil i saw it done!!
ps- i've got FK Konigsports with adjustable damping :)
polopowah
Location: Hertfordshire Drives: Ford Puma 1.7 Enjoys: Mowing grass
Post by polopowah »
on 16's you can drop about -60mm without any rubbing.
Im at -75mm with a 45 profile tyre and i get abit of tyre scrubbage on the back but nothing thats wearing the tread down!
