Stereo Problem
Biddy17
Stereo Problem
Post by Biddy17 »
My Stereo seems to start skipping and pausing randomly whenever i use it... but only when the car is moving, its not the CD's, they are all perfect condition, i was wondering if mabye a wire is loose somewhere thats causing it? any help?
/\ndy
Post by /\ndy »
yeah, most likely to be a loose wire behind the HU.
remove the HU and check all cabling, it could be just a loose spade connector thats not crimped correctly. (if you're using a custom HU anyway)
Polo Paul
Post by Polo Paul »
Most likely cause is a fooked laser is the CD/MP3 only is skipping. Try a lens cleaner, but apparently laser failure is quite common, especially in MP3 units as they have to read more and faster.
