[phpBB Debug] PHP Warning: in file [ROOT]/ext/cleantalk/antispam/model/CleantalkSFW.php on line 184: Undefined array key 1 What grill should I go for? - UK-POLOS.NET - THE VW Polo Forum
I voted for the GTi grille. Its less work than the Kamei item because you don't have to worry about filling the indent left in the bonnet, and it is easily reversible in the future if you change your mind again
gti is the only choice wen changing your grille! in my opinion the kamei one just looks to sort of aftermarket tuner! the gti one as it is an oem part keeps the polo the way it should be!
definitely the GTI grille for the above reasons, i would only ever go for the kamei grille if i was goin gor a bad boy bonnet......then i would be 50/50 about that and a slatted one.
