g40 spec
g40 spec
right peeps whats the spec of a g40 engine, what bhp, top speed, usal mpg, 0-60times, thinking about mabe gittin one of these so how hard they to come across, they expensive, really just looking for all the ins and outs of then, any info would be great
Engine:
Placing: In Front, across
Placing cylinders In line
Cylinders 4
Cilinderinherent 1272 cm3
Boring 75,0 mm
Stroke 72,0 mm
Compression 8,0:1
Max. Power 83 kW (113 hp) at 6000 RPM
Specific Power 65,3 kW (88,8 hp) per l
Specific Mass 9,8 kg/kW (7,1 kg/hp)
Max. Torque 150 Nm at 3800 RPM
Ignition Electronic
Valves per cylinder 2
Valve Adjusting Hydraulic
Cooling Liquid, closed. selfthinking fan
Camshaft Lying on top
Camshaft drive Tooth-belt
Crankshaft-bearings 5
Injection Digifant
Compressor Mechanic with intercooler
G40 with 0,72 bar
Fuel Super unleaded (98E)
Dynamo 660 watts, max. force of the current 55 Amperes
Battery 12 volts
Material engine Cast iron
Material engine-head Alloy
Transmission:
Drive Front-wheels
Placing gearbox In front, next to engine
Gear shifting Manual
Under-carriage, coach-work:
Doors 2 + tailgate
Frontwheel-suspension Independent, McPherson springs
Rearwheel-suspension Semi-independent, springs
Shock absorbers Telescopic, not gascontaining
Torsion stabilisator Front and rear
Brakes Front: Ventilated discs, Rear: Drums
Parking brake On rearwheels, manual
Rimsize 5,5J 13
Tyre size 175/60 HR 13 radial
Total Steer-rotations left/right 3,5
Measures, weights, volumes:
Length 3,725 m
Width 1,590 m
Height unloaded 1,325 m
Wheelbase 2,335 m
Track front 1,320 m
Track rear 1,346 m
Axis of rotation 10,0 m
Mass unloaded 810 kg
Max. admissible mass 1250 kg
Max. allowed roofload 50 kg
Fueltank capacity 42 liters
Crankcase capacity with filter 3,5 liters
Cooling-system capacity 6,5 liter
Performance:
Top speed 196 km/h
Acceleration 0-100 km/h in 8,6 sec.
Speed at 1000 RPM in highest gear 29,8 km/h
Consumption per 100 kilometer (90/120/city) 5,6/7,5/8,9 liter
Cylinders 4
Boring 75,0 mm
Stroke 72,0 mm
Compression 8,0:1
Ignition Electronic
Injection Digifant
G40 with 0,72 bar
Battery 12 volts
Transmission:
Drive Front-wheels
Doors 2 + tailgate
Rimsize 5,5J 13
Length 3,725 m
Width 1,590 m
Wheelbase 2,335 m
Track front 1,320 m
Track rear 1,346 m
Performance:
Top speed 196 km/h
