engine over cooling
shauni boi
engine over cooling
Post by shauni boi »
hi im new to this fourm. For the last few days i have had a problem with my engine as it has started to over cool the. When i drive it the temp will go down to cold (under 70s) and when im idle the temp will start to rise this is annoying because my heating will also go cool as the temp drops. Any 1 know why this is happening???
plzzzzzzz :cry:
willy g
Post by willy g »
alright boss ,
As u no from the other thread i,ve had this prob ,
could be down to the thermostat being stuck open , missfitted or missing altogether!!! Have a look its a easy job let me no how u get on.
i was cold this mornin im gonna look at it at the weekenk
WG
KITT
Post by KITT »
90% chance of it being your thermostat sticking open and hence too much coolant is being allowed through the radiator. Should be cheap and easy to fix :)
shauni boi
thanks guys
btw i got my thermostat replaced few weeks ago as it was overheating. so if its the thermostat stuck open what dos this mean do i have 2 replace it or what?
mysteryboy
Post by mysteryboy »
Just thought I'd add it could be the thermostat housing...
willy g
Post by willy g »
Yeah mate , replace the thermostat and as harris said above check the housing it sits in.
Its exactly wot i had mate car was fine till it overheated now it overcools
cant win hey
KITT
Post by KITT »
Just because you've changed the thermostat doesn't mean the new one's working! I had one stuck open once on my kit car's engine and went throught three replacements until I got one that actually worked! Easy test is to drop it in a cup of boiling water. Watch it open and then take it out and make sure it shuts again. Once happy, fit it to the car :)
shauni boi
went to the garage yday and they tink its not the thermostat because its just been replaced so what they did is put a sheet of paper in front of da radiator for a tempory. fist it did overheat but what i did was i cut the paper in half its had now solved it for the moment. i will have go back to vw and ask for a replacement thermostat as the 1st 1 was dodgy.
