Leaking Rear Washer on 6N2
CTR
Post by CTR »
Hi guys,
new to the polo but have searched around regarding the above. I've read that this is fairly common but can't find any answers regarding how to remove the rear boot lid panel and how to actually fix the problem properly.
I have tried to remove the panel but managed to snap 2 of the clips so didn't carry on removing it. :(
Any advice would be much appreciated. :)
danny_boy
Post by danny_boy »
you could always take it to VW an have them check it
CTR
Post by CTR »
Yeah, we've tried that, they quoted around £100 to fix it. Which I thought was a bit steep to fix what potentially is just a leaky pipe. I'd like to see for myself what the problem is before forking out.
danny_boy
Post by danny_boy »
o ryt you shuda asked them wat work is envolved then that cud hav given you an idea of doing it yourself lol, no doubt some1 on here will be able to help you tho!
paulzpolo
leaky pipe
Post by paulzpolo »
easy fix mate, to remove the panel these the two clips which you may have broken and if i remember correctly there are to screws on the panel somewhere long top,but check alround,the fitting had broken on mine part cheap and was in stock,get it repaired quickly as it can damage your central locking motor which is expensive
loud
Location: 25 miles south of Aberdeen Drives: 9N3 Polo GTi
Post by loud »
yea its easy to remove. Mine was leaking on to my central locking and making my alarm go off randomly and couldn't open my boot without the key :? luckily no permanent damage :D
inder
Post by inder »
the two screws can be found inside the boot pull handles on either side, then clips all the way around
