[phpBB Debug] PHP Warning: in file [ROOT]/ext/cleantalk/antispam/model/CleantalkSFW.php on line 184: Undefined array key 1 my polo vr6 - UK-POLOS.NET - THE VW Polo Forum
thx a lot. im workin with mu cr 5 years . the transplantation was very had work , the main problems was with electrionics( hookin up the vr6 ecu to polo rpm gauges -switching from 4 cyl to 6 cyl ) also new made cooler and radiator very thin ) also some problem with the g60 brakes and calippers couldnt fit my bbs rs .may many work but finally done. car runs superb. i put SLS ecu now should be about 192 hp. im thinkin about putting turbocharger still got lot of room in engine bay cause motor as u see is more to front and the exhaust header is on the back were turbo can fit ))
welcome to the forum mate. must say, i cant find a fault in your car except that its not mine. seen this car on so many threads, a very rare conversion indeed. and the best bit i like about it is...ITS A FIVE DOOR! hooorah!
