Help Needed from all those who have wired an amp...
samil87
Post by samil87 »
wher is the access point from which i can run the power cable from the engine bay in the car...preferably the passenger side footwell
pics plz if any1 has
thanx
i_am_ray
Post by i_am_ray »
hey man,
pretty sure if you follow the cabling from the right hand side of your engine you will find the access point at the top end of the dash board, think you can feed it through to the passenger footwell from there.
hope this helps, sorry its a bit vague :oops:
Alex_6n2
Post by Alex_6n2 »
Its easy enough to find.
As you look into your engine bay look mid right (In between the strut top and air box) and there is a rubber bung through which most of the engine electronics feed into the dash.
There's plenty of room, I've got 4AWG through it, but it s a bit of a b***h to find on the inside. Get right down, lift up the carpet and feel behind the glove box. Shove enough cable through and you'll find it :)
