Wheels...so close!
ziyaad
Wheels...so close!
Post by ziyaad »
I'm in the process of getting hold of some alloys. FINALLY! :D Is 6J x 16 and 8J x 16 with ET's of 52.3 ok? Im gonne be gettin pcd adaptors as well so i imagine that will affect the ET too?
cheers
Dee-vub
Post by Dee-vub »
Do i smeall some D90's brewing??? going by that offset! and the fact your getting adaptors!
The adaptors will usually be roundabout 20-25mm thick so will bring the ET down to about 30. So that will look sweet :wink:
My lights are coming off on thursday dude just to let you know, will be posted on friday :D We can sort payment on thurs tho.
Looking forward to seein your car with all these nice mods on it!
ziyaad
Post by ziyaad »
Right i've found a set of 2nd hand adaptors. They convert 4 x 100 to 5 x 130. I think thats the right fitment for the D90's (spot on btw Dee Vub :wink: ) theyre 20mm thick. At an offset of 52.3 will they make the wheels sit nicely?
cheers
vdubit
Post by vdubit »
Front will fit fine, et will change to 32.3 obviously. Prob need spacers though as the rims are quite narrow. Only 5-10 though. Rears will fit ok but if your running the car real low you'll prob need to roll the arches but shouldn't be too bad.
Look forward to seeing it done.
Dee-vub
Post by Dee-vub »
you should be ok with 32.3, but as vdubit said you may need a small spacer. wouldnt think 10mm....prob 3 or 5mm.
cant wait to see it.
