[phpBB Debug] PHP Warning: in file [ROOT]/ext/cleantalk/antispam/model/CleantalkSFW.php on line 184: Undefined array key 1 Bulb Upgrade - UK-POLOS.NET - THE VW Polo Forum
I want to change my headlight and sidelight bulbs so that they're whit rather than the yellow. Does anyone know what bulbs i'll need and any recommendations and pics would be appreciated? Cheers
Right ok so ive decided on getting phillips blue vision bulbs. The sidelights are W5W's and the main beam is H1. Is this right? Also it would be cool if you could change the front fogs and someone mentioned that they're H7? Does anyone know if this is true?
D-Dub wrote:Right ok so ive decided on getting phillips blue vision bulbs. The sidelights are W5W's and the main beam is H1. Is this right? Also it would be cool if you could change the front fogs and someone mentioned that they're H7? Does anyone know if this is true?
You're correct re the sidelights (W5W) & main beam H1) but I'm sure the fogs are H3. I've just fitted Osram Silverstars as my dipped headlamps and I highly recommend them; they're really bright but road legal.
