g40 Disc Upgrade
Arnoldo
g40 Disc Upgrade
Post by Arnoldo »
Was thinking of upgrading my brakes to the g40 ones. Anyone else done so. If is it easy to do and does it cost much? I have all 4 discs so base the price on that.
Cheers :P
Si_GTi
Moderator
Post by Si_GTi »
:idea: Do you mean g60 brakes? They are 280mm discs on the front (you keep the standard rear setup).
Dee-vub
Post by Dee-vub »
ui wouldnt think g40 brakes would be overly impressive on a 6n2. I'd think you meant g60 brakes, which are quite common a upgrade
Redline
Sponsor
Drives: BMW 128ti
Post by Redline »
G40 discs are 239mm from what I remember.
As Si says G60 discs are 280mm.
Arnoldo
Post by Arnoldo »
Yes I meant g60 :lol:
Were can these be bought from, how much would they cost and is it hard to do? Also would they fit in a 15" wheel?
Si_GTi
Moderator
Post by Si_GTi »
You can buy the parts from GSF, VAGparts or similar. I'm not clear on the exact parts you will require but obviously 280mm discs, pads, to fit your olop plus the other bits and pieces (carriers?)
G60 upgrade will fit behind a 15" wheel, just! 8)
Redline
Sponsor
Drives: BMW 128ti
Post by Redline »
Is it also not likely to require new calipers?
Arnoldo
Post by Arnoldo »
When u say just how bad is it? :P
Si_GTi
Moderator
Post by Si_GTi »
Redline wrote:Is it also not likely to require new calipers?
Not sure. GTi owners use the OEM calipers, right? What size brakes were fitted to non GTi models as standard?
Dee-vub
Post by Dee-vub »
pretty sure it was 256mm Si
Redline
Sponsor
Drives: BMW 128ti
Post by Redline »
GTi's and 16v's have 256mm front discs.
I think all other models have 239mm discs, but I'm not 100% sure on that.
Alex_6n2
Post by Alex_6n2 »
You'll need the calipers, caliper carriers and discs. I don't remember anything else being mentioned when I inquired about it with VAG Parts.
Dee-vub
Post by Dee-vub »
Alex_6n2 wrote:You'll need the calipers, caliper carriers and discs. I don't remember anything else being mentioned when I inquired about it with VAG Parts.
You'll need 16v hubs aswell.
way_z
Drives: 6n2 1.4 TDI
Post by way_z »
not that i think this will help much but when i swapped over my callipers on my TDi for the red gti ones it was a straight swap, no modification required..
Dee-vub
Post by Dee-vub »
The TDI must have the same hubs as the GTI then, i know some of the lesser models dont tho
