looking at a set of 16 x 8, et 35, reckon these will be fairly hassle free? also are 195 45 tyres the ones to get for a bit of a stretch?
cheers guys, any help/advise appreciated.
wheel help!
Should be ok as long as you dont go too low. Should be alright at -40mm. 195/45 will be perfect for stretch. 195/40's prob be a bit better for clearance and will stretch good to. You may need some small spacers to clear the shocks unless you have coilovers fitted. I have 9x15s et 25 and they clear ok at the rear.
What rims are they?
What rims are they?
I'd defo suggest rolling your arches, its dead easy and only takes 10-20mins a side. I've got to do mine a bit more now the 9's are on.
Spacers would mess them up completely, though thinking about it you may need them on the front. I have 8x15's on the front and had to remove the wheelarch liners, but they're ET20.
Is that an 8x16 pictured? As that dish is mental!
