Where to mount an Amp
david burton
Hello,
I've just put my sub box in the back of my mkiv, and have some choices for where to put my Amp:
1) Directly on to the sub box. The neatest solution, but I'm a bit worried about vibration. I could mount it with some rubber in between to dampen it down a bit?
2) On to the seat back. I don't really want to do this as I don't want to damage the car visibly.
3) On to the side of the car (near the rear seatbelt retractor). This seems more awkward to do.
Any opinions? Any hints and tips out there for easy places to mount it? I am restricted to the passenger side of the car (power wire length) and I also want to be able to remove the sub quickly - e.g. to get to the spare wheel!
Dave
Dave
david burton
The box is quite big - so a false floor with an amp mounted on it would just destroy any hope of carrying things in the boot. (so what?!). I'll mount the amp on the box for now and see if it works ok.
Next problem is how to stop the box from moving around in the boot?! I've seen some sub box straps - but again I would have to fix these to the seat back to get the kind of fixing I'm wanting. Before, I have just bungeed the box in, but this looks pants! It's OK at the mo (grips onto the mat) but if I brake hard then the box moves around.
Hmmm
Hmmm
david burton
The wonders of velcro!!
Used velcro to hold this "thing" down, only needed to use velcro hooks as the carpet in the boot was good evough for it, the velcro is roughly an inch and a half in width and i ran two pieces the length of the box, one at the front, one at the back and once down trying to get it off was a bit of an effort, that's how well it held. Also the amp on top is only held on by velcro (
) same method again as the box and the amp has never come off and that's been about 10 months now!!
I may have used both sides of velcro (loops & hooks) to attach the amp, (the velcro was also self adheisive) but i can't quite remember that far back! sorry
david burton
done it:
Velcro is the king. albeit a little frustrating when I'm trying to move the sub and the darn stuff is sticking like crazy to the carpet
Wiring is a little obvious, but it had to be that way. Custom box has a false front on it and it's got holes for LED's that go behind the false front and make the sub "glow". Or that is the theory. Worked in my Megane...
Can't believe I am STILL waiting for my head unit and components - Alpha car audio aren't answering the phone AT ALL, they don't seem to exist any more! Very worried.
- Josh_PoloGTi
- Drives: BMW E85 Z4 3.0i
Boot builds rock!
Still not raised my amps or got any perspex yet, but it's still loads better than it used to be!
Check it out here:
http://www.tigerstyle.co.uk/poloforum/v ... php?t=2346
Check it out here:
david burton
sweet as - very nice install indeed josh. where d'you get the lights from?
I'll consider a boot build next time - sub box is way bigger than i thought it would be!
update - got the alpine 9708RB head unit from empiredirect, a quality service that i can heartily recommend - A1. Alpha sent me the alpine component speakers asap too after they realised i didn't want the head unit any more (they were taking aaaaages). these are a christmas present from my other half
so i have for santa before i can fit them
so, got the head unit in tonight - needed it's own power supply from the battery direct! aaargh! anyway, cut hands later and it ROCKS. I can confirm that my sony unit didn't kick out as much bass as this one. the RF stuff goes well and at last i can see money well spent.
makes the 1.0L seem even more of a pleasure to drive now.
- Josh_PoloGTi
david burton
- Josh_PoloGTi
Right then...
I have one 12v power lead coming from the battery, with a 70A fuse in-line next to the battery.
I have a negative lead which is bolted to a hole I drilled in the metal under the rear seat.
I have a remote lead coming from the head unit.
These all go into gold plated distribution blocks (1 in, 4 out)
The amps and the relay take feeds from these distribution blocks (12v+, 12v- and 12v+ Remote)
The relay is used to switch the fans and neons on and off when the stereo is turned on and off.
The design was found on talkaudio (www.talkaudio.co.uk)... Go to forums, then search for "fan relay".
The relay takes high current 12v positive and negative, and uses the 12v+ remote lead's power to either let the large current 12v flow or stop it flowing... Basically, it's an electronic switch.
It lets you power 12v stuff on when the stereo is turned on.
All wires going into the relay are fused too.
Hope this helps!
Hope this helps!
