Aero Wipers
Aero Wipers
hi Tehr Folks,
Question Regarding these, Are these easily Fitted to The MkV Polo, as They do look alot better than the Stock Ones, Also is there any Advantages to These.
Ian
Ian
polo power
Cheers Bud, Thats Where i Seen them and Strongly Thinking bout getting them,polo power wrote:i bought the aero wiper kit from vag parts but, came to fit them and they kept rubbing the edge of the bonnet. you are better off getting the aero wiper kit that goes on the standard arms. hope this helps
You any pics at all mate ?
ModifiedMadness
- Sponsor
Click the link http://www.wiperblades.co.uk/flat_blade_info.php
Then at the bottom of the page select the make and model from the drop down menus, then when it comes to the year, put in 2000.
You want this one "Aerotwin Retrofit FLAT WIPER BLADE UPGRADE TWIN PACK 2 x 475mm"
Hope that helps.
Hope that helps.
Mate your a Diamond, As it says on the tin, a straight swap lol,ModifiedMadness wrote:Click the link http://www.wiperblades.co.uk/flat_blade_info.php
Hope that helps.
Think i'll order me a set of these !
ModifiedMadness
- Sponsor
polo power
just curious if anyones used the bosch ones (from the wiperblades site) and how they compare to the standard ones??
my standard ones are one there way out and was deciding out of just getting standard replacements or the aero retroefit ones
how much would a set of oem replacements cost?
any what happens when the blades on the aero's wear out, does it mean coughing up another £20-£30?? or is there an alternative.
You can buy replacement Rubbers i believe, I think they are far far better than standard ones myself, and i got the ones from wiperblades.co.ukgti_black wrote:just curious if anyones used the bosch ones (from the wiperblades site) and how they compare to the standard ones??
polo power
