Getting the front door panel off and a crazy fuel gauge :P
Hi all,
Two random things.
1) The drivers door speaker is making something in the door vibrate (i think its the window mechanism but im not too sure)
2) The fuel gauge is becoming rather inaccurate - after filling up to full, and then when u drive afterwards the gauge will go down to somewhere between full and 3/4, give it 15 mins and it goes back up to full - whats going on :S!?
Anyways, i want to get the door panel off so i can tighten up (if needs be) or even replace the factory standard speaker.
Does anyone know how to do so? and if so is it easy to replace the speaker (on citroens, they rivet the speakers on :? - drilling the rivets out on my mate saxo was not enjoyable believe me :P)
And as for the gauge, has anyone else experienced this problem?
Thanks in advance,
Alex
Ian_R
Post by Ian_R »
I Know Nothing bout the fuel Guage mate, But the door card is Easy to get off, On the actual door handle, there is a piece of Plastic that pops of, can be a pain to do, Under there you will find 2 screws un do them, Then Carefuly starting at the bottom Pull the Door card away, be carfull when popped off as the Window and wing mirror Switch are attached.
Unplug these and door card off, and to put on just do the reverse lol, When the card is off you will see the speaker, its held in by 4 Philips head screws, so no Rivets, to get to the window there is a grey layer of foamy type stuff, you would need to pull this away, I have not done this so cant comment on what it is like to remove,
Hope this helps.
Ian
polopaul
Post by polopaul »
and if you have one of the lower spec models like me theres a screw in the window wipers!the casing pops off these n you can see it in there.
Cheers Ian much appreciated. As for paul, what were you referring to - im a tad confused there :P hehehe
Also, does anyone know the size of the front speakers (in cm pls :))
Cheers,
Alex
polo power
Post by polo power »
i think the size of the components are 17cm
Ian_R
Post by Ian_R »
polo power wrote:i think the size of the components are 17cm
Yeah the Front are 17cm, If you have back ones not sire on them
oooh beefy. Any specific make you would recommend?
Cheers,
Alex
Arnoldo
Post by Arnoldo »
Dont worry about the petrol gauge. Mines fuked up to. Goes up and down as it pleases. Worked out tho....as soon as the petrol light comes on u have on average another 50 miles left in her. Thats for a 1.4 s so give or take a little depending on ur engine size ;)
Ian_R
Post by Ian_R »
alexperkins wrote:oooh beefy. Any specific make you would recommend?
Cheers,
Alex
All realy depends on your Budget mate, i went for the following,
http://caraudiosecurity.com/shop/produc ... /3829.html
And two Nice 10" Subs in he boot with a custom install, But at the end of the day its your money, But these make a hell of a difference compared to the OEM ones
they look nice - as for the tweeters, would you use them? or just stickwith the ones in the door pillars already?
Also, I thought they were 17cm holes, so will 16cm ones fit ok?
Cheers,
Alex
Ian_R
Post by Ian_R »
alexperkins wrote:they look nice - as for the tweeters, would you use them? or just stickwith the ones in the door pillars already?
Cheers,
Alex
not sure on 16cm Fitting in them, But i also replaced the OEM Tweeters, The Just fitted straight in, They sit in a piece of foam, so its pretty easy, i will say tho, when you replace the components and tweeters you will need to cut the wires in them, and solder the new ones on
had a mooch, and they make 16.5/17cm ones so its all good. How do you get the tweeter grille off? I cant really see a way to :P
Hehe soldering is like second nature to me - when you are repairing PC's all the time it kind sticks in your head.
Cheers,
Alex
Ian_R
Post by Ian_R »
alexperkins wrote:had a mooch, and they make 16.5/17cm ones so its all good. How do you get the tweeter grille off? I cant really see a way to :P
Cheers,
Alex
When you have the door card off there is off a screw just under neath take that out and gently pop it off, also when taking the door card theis one screw ta the end, ie close to the heater vent, mind and take that out
Sweet! Cheers ian :D
CHeers,
Alex
polopaul
Post by polopaul »
alexperkins wrote:Cheers Ian much appreciated. As for paul, what were you referring to - im a tad confused there :P hehehe
Cheers,
Alex
lol window wipers!haha sorry meant to write window WINDERS! :oops:
