VAG-COM
thedees1
- Sponsor
- Location: edinburgh/livingston, drives: polo gti red 5dr
Re: VAG-COM
I dont think it gives you the option, ive had a good look through all the modules but cant see anything, just stick with the normal reset process1 GTI wrote:I've got VAG-COM and im wondering if you can turn off the service light on the GTI? I turn it off by hand because it's easier. Im just wondering if you can use VAG though. Cheers
TheEggShell
Ry`
From here http://www.tigerstyle.co.uk/poloforum/v ... 10d96dd04a
This might helpMay be handy for anyone doing your own servicing
Polo 1999-02
OIL-Oil service
Press and hold button (A) (Located on speedometer below LCD display)
Switch ignition ON
Keep button (A) depressed until "---" appears in display
Release button (A)
Switch ignition OFF
INSP- Inspection service
Switch ignition ON
Release button (A)
Switch ignition OFF
If required clear the "OIL" indicator from the display as previously described
