Heater panel
CraigMK4
Heater panel
Post by CraigMK4 »
As always, i want to change the lights inside my car, YAWN i hear you cry, but heres one for ya.. how do you remove the front panel around the heater controls? The bottom half unclips easily, but the top part doesnt give at all? Theres a little movement side to side, but anything else makes it feel as though its gonna snap :s any ideas guys? Cheers! Btw i had a crack at doing the speedo etc. i had the plain old bulbs at the top with the bit of green plastic! soon sorted that out.. jus gotta figure a way to change the indicator arrows to red now :s that plastics a nightmare!
Pedro_Hilario
Post by Pedro_Hilario »
It has two little clips has most car radios have.
One on each side, above. If you use a small screwdriver it should pop right out.
It's a bit tricky to take the light bulbs out, but you'll see that when you get there.
Pedro
