AUD ENGINE
1.4 8v injection identifiable by the air intake being in the centre of the 4 runners and then the runners rolling round and into the head and a vertical throttle body
the things id like to know are (in no order) all stock
compression ratio`s
injection type and make
bore and stroke
cam design specs (angle dwell etc)
valve size and type how many angles and how many degrees)
port sizes
what oth cars has e aud engine been used in
what transmition is it mated to in the 01 5 door (ratios?)
any other things you can find out
sorry for all the q`s and all the posts this evening
