[phpBB Debug] PHP Warning: in file [ROOT]/ext/cleantalk/antispam/model/CleantalkSFW.php on line 184: Undefined array key 1 FAO: those with G60 steels and the black plastic centre caps - UK-POLOS.NET - THE VW Polo Forum
no. if you put the centre caps on before you put the bolts in you cant tighten the bolts enough without cracking the centre cap. What i do is put the wheel on (put all nuts on to correct torque etc...) then place the centre cap on cover it with a cloth and knock it on with a mallet it works every time then put the little covers over the bolts and the jobs a monkey
