M yCorrado has a twist knob that angles them, i cant find anything on the polo to lift them
(and yes, before anyone says, i know there electric, that has nuthin to do with it tho
pmlsSpeedlaw wrote:You sure they're electric? Mine aren't. And, as a result, there's no rotary knob thingie to point them downwards from the inside.
The only way to adjust them is by hand, using a long screwdriver and actually turning them down a bit.
Here's how;
Open bonnet, stand in front of car, kneel down and look at the headlights. Stick in screwdriver horizontally in some holes; you should be able to make out where they are from the position you're in. Adjust until satisfied.
There are two for each light IIRC.
