The smell of petrol in my car....
chunkychimpanzee
Post by chunkychimpanzee »
Hi everyone,
I have a 6N 16v. Sometimes when I started the engine then drive the car for about 2-3mins. There is some smells of the petrol in my car. Is that normal? Do you think I have to replace the petrol filter? or Do you guys think I have to replace something else? Cheers
Samuel
Ian_R
Re: The smell of petrol in my car....
Post by Ian_R »
chunkychimpanzee wrote:Hi everyone,
Samuel
i had a similar problem, i always had a waff of petrol, got in the car too, looked under neath, filter was leaking a little, new one and cured the problem, Mine was on a 6n2 tho. I dont know either if this will be your prob, on my car it is located at the back, sitting behind the fuel tank, have a look to see if leaking.
SteveB
Post by SteveB »
Samuel wrote:on my car it is located at the back, sitting behind the fuel tank
Same place on the 6N. I occasionally had this on my 6N 1.6 never bothered me too much.
chunkychimpanzee
Many thanks for your advice. I will have a check on the filter, and see whether there is any leak... Cheers...
Ian_R
Post by Ian_R »
chunkychimpanzee wrote:Many thanks for your advice. I will have a check on the filter, and see whether there is any leak... Cheers...
replace it anyway, there about 6 or 7 quid mate, and fit your self, piece of p*** !
chunkychimpanzee
Is it simple as that?? I thought it would be a nightmare job to carry out, as I think anything to deal with the fuel is difficult and not simple as I thought... Anything that I have to be aware of? Cheers
Samuel
Ian_R
Post by Ian_R »
chunkychimpanzee wrote:Is it simple as that?? I thought it would be a nightmare job to carry out, as I think anything to deal with the fuel is difficult and not simple as I thought... Anything that I have to be aware of? Cheers
Samuel
Nah piece off p*** mate, its on the outside, Just need to make sure you put it on the right way, as the filter only works one way lol,
