front tweeters packed up!!!
doublefifteensmk4
Post by doublefifteensmk4 »
front tweeters packed up!! common thing ive heard!? any easy solution to this please post!!!!!!
SteveB
Post by SteveB »
Buy new ones :P
Do you mean the standard ones? If yes then you could buy some aftermarket front speakers like I have, then fit the tweeters in the same place.
pologarry
Post by pologarry »
what size are the tweeters and the door speakers ? as i'll soon be upgrading the sounds in my daughters car............
SteveB
Post by SteveB »
Door speakers are 6.5" (17-17.5cm?). Tweets are just tweeter size (about 1.5" from memory). Lift off the grills on the dash and take a look. Then prise up the plastic tweeter holder. The two sets of wires attatched are one input from the head unit, then the output to the doors. The grills don't normally stay in very well cos the clips are a bit rubbish.
Hope this helps,
Steve
doublefifteensmk4
no worries ill jus pop down the breakers yard pop some old 1s out give em a blast, job done!!!
