Sub or no Sub?
chrisash32
Sub or no Sub?
Hi All!
I have been thinking about this now ever since i got my Polo!
I have in my loft, out of my old car a 1000w sub!
It was really needed in my old car, but i am not sure about the Polo.
The stock VW sound system in the new ones is quite good.
Also the bass is quite good as well.
I felt a bit short of space in my last car, which had a bigger boot.
I think i could just squeeze the sub and tool box in the polo.
Not sure what i should do guys, what do u think?
If not, the sub will be for sale!!
Chris
Chris
mc_iver_9n
ModifiedMadness
- Sponsor
chrisash32
chrisash32
chrisash32
Nah just pull the HU out and plug a wire into the block. mines switched powerchrisash32 wrote:Do you have to take the head unit to bits?dino wrote:I think i have the wiring diagram somewhere! I'll dig it out and give it to you at pod if i have it.
Not sure off the top of my head as my mate installed mine.
Also is yours auto power on ur do you have a switch?
chrisash32
hmmmm,
under seat sub sounds good.
I opted out of the under seat draws in mine. so i assume there is sum room under there.
I guess there is a DIY guide on how to get the wires through the firewall?
I was going to fit it before the GTI Festival, but i aint sure.
Will see what Dino gets me!
Chris
Chris
A quick search found this one:
- 8"
- Active (built in amp)
- 150 Watt (under your seat it will feel more)
- Size 25 x 26.5 x 11cm
Click for more details
Just check with anybody else thats got a sub as to where they have put their power wires. In the mk4 a common places to route the power to the boot is through the bulkhead/firewall where the washer pipe goes through into the passenger footwell/ behind the glove box.
If that works on your model you could probably find a way of routing the cables from the centre console, under the carpet to either or both seats.
Hope that helps,
Steve
- 8"
Hope that helps,
Steve
