Full Beam Light Bulb
ticki
Sponsor
Post by ticki »
Does anybody know where I can get some High performance Main beam bulbs?
Which is the correct fitment for the GTi?
cheers
Ticki
Luke'sGti
Post by Luke'sGti »
main beams are xenons on a Gti as far as i am aware :?
Si_GTi
Moderator
Post by Si_GTi »
Luke'sGti wrote:main beams are xenons on a Gti as far as i am aware :?
Nope.
The xenons are dipped-beam only. Main-beam and sidelights are regular bulbs. AFAIK, the main-beam bulbs are H1 :)
Check out somewhere like powerbulbs.co.uk or ultraleds.co.uk for prices...
ticki
Sponsor
Post by ticki »
Nope.
Thanks pal. I'm a bit confused because the powerbulbs website suggests the Main Beam bulb is H4???? :?
garnier
Post by garnier »
The H4 is probably for the non-Gti main beam
Luke'sGti
Post by Luke'sGti »
Nope.
I do apologise i mis-read what was being asked.
vdubit
Post by vdubit »
The main beams are definatly H1. H4's are not fitted to any mk5, only the mk4. A non gti uses a H7 for dip and H1 for main.
It depends on the look you want to acheive. Blue vision give you that xenon blue tint, where vision plus give you a crisp white with an extra 20% brightness :P
mk4 glx 1.6
Post by mk4 glx 1.6 »
CymruPolo wrote:What would be best, Philips Vision Plus or Philips Blue Vision?
Vision Plus if you want the best light output, to be able to see where you are going.
Si_GTi
Moderator
Post by Si_GTi »
Exactly. I have a pair awaiting fitment on my Polo. Much better to see where you are going than to worry about what colour it might be :wink:
