16 valver - Broken gear stick linkage
KITT
Post by KITT »
I know the 16v is supposed to have a weak gearbox, but has anyone else had this?
The bottom of my gear stick has crumbled apart so is no longer connected to the pushrod that go into the gearbox. I can't select any gears :( Had to have the car towed to a garage to be fixed. Just wondering if anyone knows how much it's going to cost? They won't be able to look at it until tomorrow.
Alkhemist
Post by Alkhemist »
I've just had exactly the same problem. I had to be towed from West Yorkshire to Gloucestershire, as I couldn't get the car in gear. I'd just had a new gearbox fitted on my 16V about three weeks ago, and I was worried it might be that! It was a broken linkage that cost just £35 to fix... Phew!
tinny_uk_75
Post by tinny_uk_75 »
I had a gearbox issue with a car before. If you can jack up the front of the car to get to the gearbox, ( I jacked mine with and sat it on the spare wheel so I could crawl under) and get it into third gear by hand then you can usually get it home.
Not the most practical thing but it does save a big tow bill!
