Passenger side electric window help.
lilpee123
Post by lilpee123 »
My passenger window has recently started to play up.
I press either button (drivers side or passengers) and the window will go down very slowly but will eventually go down. When it comes to comin g back to the 'up' position its very slow again and gets about 3 quarters of the way up then gives up and goes back to the half way position.
Any ideas? Ive had a look etc and cant see any thing stuck or broken wires.
James
Arnoldo
Post by Arnoldo »
Try spraying wd40 down near the moving parts. They might have alot of dirty around them which could be causing them to stop.
lilpee123
Post by lilpee123 »
will try that....thanks
Anyone got any other ideas just incase that doesnt work? Dont want to keep taking the door card off etc.
SteveB
Post by SteveB »
lilpee123 wrote:Dont want to keep taking the door card off etc.
I'd say leave the doorcard off til it is fixed :P
If its going up a bit then coming back down on its own then to me it sounds more like an electical problem. Just take a good look at what happens whilst the doorcard is off when its goes up/down.
human traffic
same
Post by human traffic »
something like that happened to me it turned out the clip on the camp that holds the glass had broke. i ended taking the door apart and drilling a small hole through the plastic bit that hold the camp and put a make shift pin through it.
SteveB
Re: same
Post by SteveB »
human traffic wrote:something like that happened to me it turned out the clip on the camp that holds the glass had broke. i ended taking the door apart and drilling a small hole through the plastic bit that hold the camp and put a make shift pin through it.
I've done that on both clips on both windows on the 16v and once on the GLX. Its a poor design really because its only a little bit of plastic that is meant to clip into metal.
I was on Dartmoor when I pressed the up window switch, all sounded normal until I realised there was no glass! Luckily I had a screw driver in the boot to strip the doorcard off and push the glass back on. Much to our amusement but I couldn't use the window for the day for fear of the glass falling back into the door again. The next day I decided to check both doors and they both needed fixing, my garage suggested a whole new mechanism. But at about £50-60 a door I decided to fix it myself, there is a slight rattle which if it really bothers me I'll strategically place some rubber to quieten it down.
I took some pics so will post it up at some point.
PD
Post by PD »
I have exactly the same problem! I need to get a replacement switch sorted as the person who owned my car before obviously has tried to take the switch out and broken it a bit! probably when taking the door panel off to fix the speaker (which is still broken)
does any one know where i could get a new switch for the electric windows??
