Removing front grill surround
Pearbo
Post by Pearbo »
Could someone please give me some advice on this, this is the part that runs underneath the lights and around the front grill.
it is a 1L R reg polo L.
R1CH
Post by R1CH »
remove the actual grille,,which is straight forward,,then rmove the two 7mm nut things under the indicators and slide it toward you..have fun.
LeMeph
Post by LeMeph »
you have to take the grill off first, which is just a few clips accessed with a screwdriver from the top, then a few at the bottom. You can usually reach these with your hands while gently pulling back the grill.
Once the grill is off take out your side indicators. There attached using a small screw that needs a 6 socket if memory serves...
Then slide out the indicators and let em dangle. Now revealed to you is more screws, same size socket as before i think and voila your done.
Pearbo
Post by Pearbo »
Thanks for help, looks a lot nicer now.
R1CH
Post by R1CH »
show some pics matey.
Pearbo
Post by Pearbo »
you dont want to see my rusty front lol.
LeMeph
Post by LeMeph »
that sounds like an inuendo...
R1CH
Post by R1CH »
oohh,,,does sound a bit wrong actually :lol:
omricn
Post by omricn »
hi, to the thread opener.. i, like u, (wouldnt that last sentence sound really weird without the commas :? ) really hate how that grill surround thingy looks and am looking for an idea to change it, how did u do? any picts??
Pearbo
Post by Pearbo »
I didn't swap it for a different style, i just replaced it cos it had a big hole in it.
