Rear drums to disk brake conversion?
daa709
Post by daa709 »
Hello,
Does anyone know anything about converting the rear drums to disks? :?
Is it hard to do? Would I just need the original disks and calipers? Or is it more complicated?
Thanks!
Jeff GTi
Post by Jeff GTi »
its more complicated than that mate im affraid
you will need a full rear beam already with the disks and calipers, different setup for the handbrake, brake bias's etc
its a decent sized job, but can be done if you had the money or knowledge
daa709
Post by daa709 »
Sounds evil.. :(
I'll give vagparts a go see if they know what I need, and how much it would cost!
Tbh, the rear drums are s**t (they even squeak when coming up to lights sometimes), so i'd rather replace them.
GU!NN3SS
Post by GU!NN3SS »
How did you get on with this? (if you did it)
andy947
Post by andy947 »
Drums are pretty efficient when working properly.
You will see no benefit from swapping to disc other than looks - if the brakes are squeeking overhaul them, if you cant do that, you cant do a disc swap.
GU!NN3SS wrote:How did you get on with this? (if you did it)
Ive nearly got all the parts to do mine. Just need the Caliper setup. Got the stubs, bearings, discs, pads and cables plus new speed sensors hehe :D
GU!NN3SS
Post by GU!NN3SS »
hmm disks do look soooo much better though! and im due to change the drums and shoes anyway! decisions decisions!
Your due to change the drums :shock: how on earth did you wear them out!?
GU!NN3SS
Post by GU!NN3SS »
No idea! Just came up on the service that they were due for a change!
Wouldnt be surprised if it was just stealership tactics!
daa709
Post by daa709 »
Na I didn't do it in the end, looked up the parts and got majorly confused. I dont mind doing it, but if someone points me in the right direction i'll be sorted.
One day!
