Rear drums to disk brake conversion?
Posted: Tue Jun 19, 2007 7:14 pm
by daa709
Hello,
Does anyone know anything about converting the rear drums to disks? :?
Is it hard to do? Would I just need the original disks and calipers? Or is it more complicated?
Thanks!
Posted: Tue Jun 19, 2007 7:40 pm
by Jeff GTi
its more complicated than that mate im affraid
you will need a full rear beam already with the disks and calipers, different setup for the handbrake, brake bias's etc
its a decent sized job, but can be done if you had the money or knowledge
Posted: Tue Jun 19, 2007 10:27 pm
by daa709
Sounds evil.. :(
I'll give vagparts a go see if they know what I need, and how much it would cost!
Tbh, the rear drums are s**t (they even squeak when coming up to lights sometimes), so i'd rather replace them.
Posted: Wed Nov 14, 2007 3:06 pm
by GU!NN3SS
How did you get on with this? (if you did it)
Posted: Wed Nov 14, 2007 4:05 pm
by andy947
Drums are pretty efficient when working properly.
You will see no benefit from swapping to disc other than looks - if the brakes are squeeking overhaul them, if you cant do that, you cant do a disc swap.
Posted: Wed Nov 14, 2007 4:28 pm
by alexperkins
GU!NN3SS wrote:How did you get on with this? (if you did it)
Ive nearly got all the parts to do mine. Just need the Caliper setup. Got the stubs, bearings, discs, pads and cables plus new speed sensors hehe :D
Posted: Fri Nov 16, 2007 9:29 am
by GU!NN3SS
hmm disks do look soooo much better though! and im due to change the drums and shoes anyway! decisions decisions!
Posted: Fri Nov 16, 2007 9:46 am
by alexperkins
Your due to change the drums :shock: how on earth did you wear them out!?
Posted: Fri Nov 16, 2007 9:55 am
by GU!NN3SS
No idea! Just came up on the service that they were due for a change!
Wouldnt be surprised if it was just stealership tactics!
Posted: Sat Nov 17, 2007 9:36 pm
by daa709
Na I didn't do it in the end, looked up the parts and got majorly confused. I dont mind doing it, but if someone points me in the right direction i'll be sorted.
One day!
