[phpBB Debug] PHP Warning: in file [ROOT]/ext/cleantalk/antispam/model/CleantalkSFW.php on line 184: Undefined array key 1 changing 16v temp sender ( with pic) - UK-POLOS.NET - THE VW Polo Forum
I assume the red arrowed part unclips with the shiny clip and then the temp switch is the yellow arrowed part which comes out when you remove the big U shaped circlip,at which point water pisses out unless i clamp the big pipe?
