h4r1s wrote:Brake and clutch are a straight swap, the accelerator pedal is a bit bigger and requires some glueing. As it says in the listing it's a 10min job
Hope that helps,
Haris
Yeah thats cool. I saw in the listing its a 10 minute job. Seems fairly straightforward and easy to do. The listing says ON SOME LUPO'S, AUDI TT's AND MARK 4 GOLFS THE ACCELLERATER PEDAL MAY NEED TO BE BONDED OR SUPER-GLUED ON
It doesnt say anything about it needing glue on a Polo. Excuse my ignorance here. I would guess like you say it does due to it being bigger.
You have to take your pedals off first, the accelerator just clips off, the other 2 will be a bit more difficult. Once you get them off, get the TT pedals in some nice hot water so the rubber stretches a bit, then try and put them on using the outlines as guidelines. For the accelerator use either bonding glue or blue-tak.
MaxZ wrote:You have to take your pedals off first, the accelerator just clips off, the other 2 will be a bit more difficult. Once you get them off, get the TT pedals in some nice hot water so the rubber stretches a bit, then try and put them on using the outlines as guidelines. For the accelerator use either bonding glue or blue-tak.
cool. blue-tak sounds a better idea. if I sell it then I would wanna put it back to standard fairly easily!!
yeah a great mod to do, mine were about £20 from ebay. had to glue the accelerator one on, i figure why would anyone want to go back to black rubber ones!
