[phpBB Debug] PHP Warning: in file [ROOT]/ext/cleantalk/antispam/model/CleantalkSFW.php on line 184: Undefined array key 1 Doors not closing properly...common problem or not? - UK-POLOS.NET - THE VW Polo Forum
no, the seal is just not on properly, you no if you want to run your head unit cables through to the back you have to pull up the seal to put them under the carpet, well sometimes in the corners of the door at the bottom it isnt pushed in fully! try that
my passenger door needs a bit of a slam to shut it properly too, will have to do some adjusting this weekend along with moving the number plate lower and giving it a bloody good clean (weather permitting!)
nafeGTI wrote:my passenger door needs a bit of a slam to shut it properly too, will have to do some adjusting this weekend along with moving the number plate lower and giving it a bloody good clean (weather permitting!)
lol at least i aint the only one with a filthy car as to the above ive have this problem.
Ive just noticed that my drivers door hinge-catch (the bit that stops your door opening too far) is moving slightly and tightened it up. open your door fully and look at that to see if that is moving. Tighten it u and see if that helps.
Try this - try and shut it lightly and then open it and open the drivers door and try to shut the passenger door again. Should close with the lightest touch. Something to do with air pressure in the car (can't remember who told me this at gti inters camp).
it's a nightmare isnt it?! I cleaned just my wheels last night as it can make the whole car look clean when it speeds by
