Quick shift!!
polobear
Quick shift!!
Post by polobear »
Sorry but I'm so excited..! Just found out B&M do a quick-shift kit for the 6n2 and it's only £130. Has any one got one fitted? if so are they any good?
PD
Post by PD »
What exactly is a quick shift?? I am guessing its to do with the gearbox?
polobear
Post by polobear »
PD wrote:What exactly is a quick shift?? I am guessing its to do with the gearbox?
A quick-shift reduce the amount of throw of the gear stick
allowing quicker gear changes.
Bepe
Post by Bepe »
why dont you just cut the gear stem down?
Redline
Sponsor
Drives: BMW 128ti
Post by Redline »
Bepe wrote:why dont you just cut the gear stem down?
All that does is make the stem shorter.
A genuine "quick shift" kit moves the actual pivot point which reduces the actual throw of the gear shift.
See here: http://www.tigerstyle.co.uk/poloforum/v ... php?t=9083
LeMeph
Post by LeMeph »
thatd surely fit a 6N aswell right....?
Kam Racing
Re: Quick shift!!
Post by Kam Racing »
polobear wrote:Sorry but I'm so excited..! Just found out B&M do a quick-shift kit for the 6n2 and it's only £130. Has any one got one fitted? if so are they any good?
I'm doing them for £120 in the thread redline gave a link to.... some modifications are needed to fit this to the polo, which can be found in the thread.
I've got 8 left, not sure if I'll be able to get any more after that as i believe they're a discontinued line so I'd hurry if you don't want to miss out on one.
http://www.kam-racing.com/product_info. ... cts_id/667
LeMeph wrote:thatd surely fit a 6N aswell right....?
as far as i know it has only been fitted to the 6N2, did the gearboxes change in the facelift?
