hiya
i've got a mk5 polo tdi.i want to remove the POLO and the TDI badges. what is the best way to do this, and are there any holes behind? what about the vw badge in the middle?
Badge Removal
polo2k
behind the polo nad the tdi there are no holes all you have to do is get a hair dryer and heat them up nad then pull a fine piece of string thru the glue behind
when i did mine i removed the boot interior and heated the metal from the bach and just pulled leaving no adhesive( to remove the bootinterior i think there are 2 screws in the interior handle and then its cl;ipped)
to remove the rest of the glue you can rub avay at it after heating of use white spirit or meths and then after your all done just wax the area over to get the shine back.
if your interested on removing the door bumpstrips then you will find holes but not on a mk4
