vw badges
Detailing & Bodywork
billy_boy18
vw badges
Post by billy_boy18 »
how hard is it to remove the vw badge on back and front of a polo 9n tdi?
and the other gadges as well liek polo and tdi?
are they just stuck on with dubble sided tape or clips?
and any tips on spraying the badges black?
dino
Sponsor
Post by dino »
Rear VW badge along with the POLO and derivative badge is all stuck on with double sided tape. I used a hair dryer to heat the tape and then sliced through it with dental floss. Can remove the residue with any tar remover (or WD40 i think). Little polish up afterwards and jobs a goodun'.
To remove the front badge you need to remove the grill. 2 torx bolts on the top and two clips on the top. carefully pull forwards and up to release the clips at the bottom and then you will see the back of the VW badge which is again held in with clips.
