Engine bay clean up
stani540
Engine bay clean up
Post by stani540 »
after recently fitting my BMC with two standard breathers like so:
i decided to take Bepe's advice about fitting the one way brether from the original airbox as my oil levels were getting seriously low
so i rang round a few scrappies looking for a new engine cover but could'n be doing with paying 30 quid upwards for one so i thought id hack up mine and worry about getting a new one later!!
and here are the pics
new breather from air box
and then i chopped up the cover to tidy things up abit
what do you all recon???
Redline
Sponsor
Drives: BMW 128ti
Post by Redline »
Nice work, looks a lot tidier with the cover back on.
JarnoVWPolo6N
Post by JarnoVWPolo6N »
Looks a lot nicer with the cover on, nice cutting you did there !
Mind the intake hose against the radiator hoses - it will wear through due to the vibrations. Ive had to replace mine already!!! Ive got some new tubing anyway its too scary to use the original knowing what it can do :P
I must say that is rather tidy might do that on mine :)
stani540
Post by stani540 »
alexperkins wrote:Mind the intake hose against the radiator hoses - it will wear through due to the vibrations. Ive had to replace mine already!!! Ive got some new tubing anyway its too scary to use the original knowing what it can do :P
its not the standard bmc one alex its the feed from my k&n 57i and thats where k&n tell you to put it and have had it on for almost two years now and its fine i think what sort of problems have you had any pics??
Ye ill get some pics - basically the vibration from the hose touching the airfeed caused the airfeed to rub into the pipe and rupture it, therefore spilling boiling coolant everywhere
stani540
Post by stani540 »
saw what you meant about the hose this morning what are you doing to solve it just relocating the air feed?
Kam Racing
Post by Kam Racing »
Looks much nicer.. which of the 2 breathers did it replace?
stani540
Post by stani540 »
it replaced the one marked 2 in the red box and the breather comes from the arrow marked 1 crankcase i think?
topped up with oil this morning so all should be fine now i hope
JarnoVWPolo6N
Just a suggestion, some red ignition wires, I see that those run over your cover, recon it would look smashing as a little finishing touch 8)
Bepe
Post by Bepe »
stani540 wrote:it replaced the one marked 2 in the red box and the breather comes from the arrow marked 1 crankcase i think?
good lad, i havent had any oil lossage sinc i changed mine! 8)
stani540 wrote:saw what you meant about the hose this morning what are you doing to solve it just relocating the air feed?
Replacing it - getting some of that ducting off ebay thats glass fibre with a neoprene coating and piping it down to the fog grille.
The metal pipe will cause damage wherever it is :(
As for that filter, it will get totally full of oil fairly quickly even more so if the car is pushed a bit here and ther :P Ill get some pics of what i did soon ;)
