Lowering question
Lowering question
Hey guys, i want to lower the polo because i've got myself some 15's to put on it but i don't want it to look like a tractor! How low can i go on just springs? Because i'm a bit skint and can't really afford to fork out for shocks as well. Also, how much am i looking to spend? Cheers for help, Craig
set of srpings cost u about £60, i got a philj suspenion kit for £130. I got qutoed £60 for fitting jst springs, or £100 to fit springs and shocks. Youll then need your tracking and camber done, cost me £80 to get it properly done using a laser and a computer lol.
You should be fine lowering 40mm on just springs, but ig u want to lower for perfromance perposes i reccomend getting shocks as well
Redline
- Sponsor
- Drives: BMW 128ti
If you can tell me which part of the MOT involves measuring the length of the spring relative to the damper, I'd be quite intrigued.Gomez wrote:also lower than 40mm on standard shocks is an MOT failure as i understand it.
The reason people suggest not to go more than 35-40mm is because the springs and dampers are mismatched in their rates, meaning the ride can be awful combined with the possibility of dampers wearing quicker.
got around to writing a guide coz some1 had to lol check it out
http://www.tigerstyle.co.uk/poloforum/v ... 219#248219
Maybe not MOT failure then jsut something i heard but i still get the feeling he was right about the springs popping out if the damper fully extends be it pot hole etc?
It was an ex mechanic friend of mine.
I wouldn't suggest doing just springs in any case. or if you are not running them for too long with upgrading dampners as well.
