airbag light
armo
airbag light
Post by armo »
how can i switch the airbag light off? it always on :cry: , is der a fuse 4 it or do i av to open the clocks up an pull the bulb out?
You use Vag Com its fairly simple, or you ask a VW dealer really nicely, or you can try leaving the battery disconnected for and hour or so which may clear the fault.
armo
Post by armo »
[quote="alexperkins"]You use Vag Com its fairly simple, or you ask a VW dealer really nicely, or you can try leaving the battery disconnected for and hour or so which may clear the fault.[/quote]
der ain no faults, ma airbags av gonoff so i put on a steeringwheel but not an airbag one!
