braided brake hoses, anyone make them?
jj_2388
Post by jj_2388 »
as my title says, anyone make braided hoses for the gti? if so any idea on price?
thanks JJ
tegwin
Post by tegwin »
If you know which end connectors you want and what length...just call rally design...they can sort them out for you..
Think the ones for an old ford cost me about £8 each custom made...
Si_GTi
Moderator
Post by Si_GTi »
I hear Goodridge are normally the best bet for the braided hoses. Quite fancy some myself!
dubbprince
Post by dubbprince »
it'd be goodridge really...but black diamond also do braided hoses too.
they only provide a 4 line kit though...the GTI has 6 lines in total. the extra two are located on your rear axle and are half hard lines and half rubber (steel piping with rubber hosing)...
you can't buy those two hoses in any set...they'd have to be custom jobbies and i've had a qoute from Pertek the hose specialists and they wanted £130 for a pair!!
you have two- one each side for the front.
you have two coming from the axle to the car itself.
then the two i spoke of above...
I use Goodridge and you can get the kit through GSF with discount! :wink:
sorted
Post by sorted »
I have goodridge front braided hoses on my GTI 8)
Another note, see when fitting then to the caliper - a copper washer has to be put in to stop them leaking - if i take the hose off, where will i get a replacement washer ?
Neil
jj_2388
Post by jj_2388 »
thanks, i know about the 6 hoses, just was interested in who made them. are they sold for the gti or is it ones from another car you use?
Dee-vub
Post by Dee-vub »
I have goodridge draided all round
Seem really good!
Si_GTi
Moderator
Post by Si_GTi »
Dee-vub wrote:I have goodridge draided all round
Seem really good!
Have you got part numbers for the kits you bought for front and back please Phil? I've got about 4 or 5 different part numbers and would like to narrow this down to the correct ones.
Hope you kept your delivery notes / invoices!! :wink:
Dee-vub
Post by Dee-vub »
Yes im pretty sure i did...but im offshore :( , i know you need ones WITH the union plugs
Si_GTi
Moderator
Post by Si_GTi »
There's no rush mate :wink:
Tim_GTi
Post Whore
Post by Tim_GTi »
what advantages do braided hoses have exactly?
Dee-vub
Post by Dee-vub »
They orginally have rubber hoses that expand under pressure(when the pedal is pushed) The braided hoses minimises the expansion under pressure
Tim_GTi
Post Whore
Post by Tim_GTi »
Dee-vub wrote:They orginally have rubber hoses that expand under pressure(when the pedal is pushed) The braided hoses minimises the expansion under pressure
which makes braking better?
Redline
Sponsor
Drives: BMW 128ti
Post by Redline »
Well it should give a firmer and more direct brake feel at least.
Mouse_GTI
Post by Mouse_GTI »
Any part numbers Phil?
