air filter
pip_polo
air filter
Post by pip_polo »
does any one have a picture of it in their engion?
i'm confused with all the hoses about the place.
've fitted mine on and i hasn't changed sound much
(which makes me think its wrong as the little change in noise will prob be my engion dying slowly.)
cheers
1.4 8v btw
LeMeph
Post by LeMeph »
your air filter is the hugfe3 black piece of plastic that takes up the most room in your engine bay. It has like 4 or 5 screws stuck in it that are all numbered up.
Get a pic of what youve done up. Im guessing youve attached some kind of mushroom filter to the end of the air feed for the filter housing (on the left hand side?). If you didnt take out the original filter before attaching the new filter then it will do bugger all for nosie or eprformance.
pip_polo
Post by pip_polo »
so i need to take out the big black box and basically replace that with the filter i have?
does anyone have a picture?
cheers
pip_polo
Post by pip_polo »
this is how it looks..
this is where i'm confused..
and this is what i've done..
i've taken the old air filter out and just put that on cuz i was confused when i took out the box as there was a black pipe lables '1' on the picture. dont know what this was for..
and number '2' is there where i should connect the filter straight too?
cheers
bstardchild
Moderator
Post by bstardchild »
LeMeph wrote:your air filter is the hugfe3 black piece of plastic that takes up the most room in your engine bay. It has like 4 or 5 screws stuck in it that are all numbered up.
You're a bloody good guesser!!!!
pip my take on this
1st - That's a mesh filter and I can assure you they don't filter much if anything at all
2nd - if you want the waaaaaarp noise it won't provide it as it's way too large
My track day monza has no induction noise at all due to a very large filter
3rd - why would you want to replace a very efficient paper filter that give excellent flow rates and when housed in a sealed air box gives both min induction noise and max filtration
4th - haven't found anything other than a high quality induction kit with a sealed box containing the filter and a proper cold feed that does anything other than make a car go slower, use more fuel and sound crap
Sorry strong views :roll:
david burton
Post by david burton »
for (1) basically you need to get a small breather filter for that pipe, that will help stop all that nasty oil breather stuff getting back into the engine.
otherwise what you've done is fine, if a little diminishing to performance....
pip_polo
Post by pip_polo »
i think i'll just remove it.
put it back to standard.
the car also really smells like petrol since i've done it so somethings wrong.
not long till my new car though :]
JoeG07
Post by JoeG07 »
lol yeh i spent ages playing around with my inductiion kit before giving up and putting it back 2 standard, that didnt do much but sometimes it gave a well nice deep hum at higher speeds. I put it where the old box was it just sits straight on
pip_polo wrote:i think i'll just remove it.
The smell is due to the crankcase breather not having a filter and/or being to close to the cabin air intake :P
NOZ
Post by NOZ »
That pic of what you done really made me :lol:
Anyway, firstly a universal kits isn't good for your car seeing it doesn't filter much anyway and is too huge for that type of car. So its best to get one specificly made for your car ie pipercross, K&N etc.
Then take off the black box and put the kit on the mouth of the throttle (2). Best to put a metal heat shield between the filter and the engine so heat hot air doesn't make it in. A specific kit would also have the fixtures for the breather pipe (1). However buying a small breather filter would seperate the two stopping that air getting back in. job done. If your selling then best to revet it to standard and not bother anyway.
pip_polo
Post by pip_polo »
yeah should be getting a lupo tdi or polo tdi
either, should the right one come along before christmas.
:twisted:
NOZ
Post by NOZ »
Then its really no use spending money on this anymore if your getting something so soon cos you'll probably revert this to get a wider range of buyers anyway.
