Door pin removal mod
aweis_786
Post by aweis_786 »
Hello everyone, just wanted to show u all this mod i've done to the door pins on my 6N2.
I did this mod so nobody can do the wire hanger trick on me :D Also it gives added security so when i enable the alarm the LED's flash red. So guys what you think. Thanks for looking.
DanDiesel
Sponsor
Post by DanDiesel »
looks good and if it aids security then it can't be bad!
sorted
Post by sorted »
Shorten'd door pins is a common mod...
THOUGH, the red led isnt really. You said you wired it to the alarm - is it a standard alarm you have - or did you get one fitted?
If its standard - where have you connected the leds?
Just usefully questions incase anyone wants to add the LEDs to there polo!
Neildo
Tim_GTi
Post Whore
Post by Tim_GTi »
Neildo
arite i was gunna say neil, you dont need em the Gti has them!!!
sorted
Post by sorted »
Tim_GTi wrote:
Neildo
Well your half right :P ... just the drivers door :lol:
Though you can easily wire it up to the passengers too :P
Arnoldo
Post by Arnoldo »
How does it stop the hang trick tho? Im lost :D
Tim_GTi
Post Whore
Post by Tim_GTi »
Arnoldo wrote:How does it stop the hang trick tho? Im lost :D
if the pins are low enough you cant get a grip on them to pull them up and unlock the door!
aweis_786
Post by aweis_786 »
I got a mate of mine to wire the LED's to the aftermarket alarm that came with the car. Im not sure about the wires he hooked them up to.
The wire hanger trick is used by thieves to pop up the door pins to unlock the car door. It now carnt be done to me because ive took the pins out :)
