anyone know anything about these?
i think they use a 1.6 16v engine but different from the 6n2 gti anyone know what engine number they were and what kinda of power they had?
german 6n gti
JarnoVWPolo6N
JarnoVWPolo6N
difference is in the head, cams, variable valvetiming (when comparing to mk5 GTI) exhaust, inletmanifold, throttle and ECU and of course longer stroke to gain the 200cc between a 1.4 and 1.64paws wrote:thanks very much mate
do you know the differences between the 1.6 16v and 1.4 16v is just the block or is cylinder head,gearbox,wiring etc different?
Kam Racing
JarnoVWPolo6N
Kam Racing wrote:is that the only difference? do you know if a manifold designed for the AJV engine would fit the AVY engine?JarnoVWPolo6N wrote:1.6 16v GTI with 120 BHP (5BHP less then mk5 GTI due to no variable camtiming) with enginecode AJV
Read it m8
But yes, an AJV (6N/mk4 GTI) exhaustmanifold will also fit the mk5 GTI's, and fit all 16v's mk4 & mk5JarnoVWPolo6N wrote:difference is in the head, cams, variable valvetiming (when comparing to mk5 GTI) exhaust, inletmanifold, throttle and ECU and of course longer stroke to gain the 200cc between a 1.4 and 1.64paws wrote:thanks very much mate
